 Post subject: 2 shelves, same theme,1 allows "Show icon grid",1 not-SOLVED
PostPosted: Tue Jan 03, 2023 10:50 pm
Nexus Ultimate.
I have two shelves, both using theme "Office".
I have selected "Appearance | Show Icon Grid" on one and it displays a grid nicely.
On second, I went to select same and the "Show icon grid" is grayed out and unselectable.
Hunted around looking for other options which might disable this but can't seem to find one.
Any suggestions what might disable one and not the other ?
 Post subject: Re: 2 shelves, same theme, 1 allows "Show icon grid", one do
PostPosted: Wed Jan 04, 2023 2:55 am
"Show icon grid" becomes grayed out if the Icon Alignment below is set to 'Centered'.
PostPosted: Wed Jan 04, 2023 6:12 am
Fixed. Thank you sir.
Never crossed my mind as I thought divider grid and it really is just a grid for the full shelf which is obvious when I go with left justified and set show icon grid.
