 Post subject: Calcolatrice
PostPosted: Thu Jul 28, 2022 3:20 pm
e' possibile inserire la calcolatrice di windows in una scheda ?
 Post subject: Re: Calcolatrice
PostPosted: Thu Jul 28, 2022 3:25 pm
"It is possible to insert the windows calculator into a tab"
Sure, just drag a shortcut from the Windows Start Menu.
If you are running Winstep Xtreme or Nexus Ultimate, the Shelf has an 'Apps' tab that displays all the UWP Apps installed on your system in a single tab. You can drag from there too.
PostPosted: Thu Jul 28, 2022 3:48 pm
LOL! Even I didn't need a translation for that. (Now and then remembering the odd bit of Latin can be quite useful.) :D
But really, hasn't anybody these days heard of the SIAS principle? 'Suck it and see', as the bishop said to the actress. ;)
How will it all end?!
IN FIRE!
Users browsing this forum: winstep and 74 guests
