 Post subject: Is it possible to add folders and songs at the same time?
PostPosted: Mon May 09, 2022 9:46 am
I don't know how to add my entire music library thats are a bunch of folders with the songs into them. Is it possible to use [LINK REMOVED BY ADMIN - OH LOOK, A PESKY SPAMMER AFTER ALL] at the same time in the media player?
 Post subject: Re: Is it possible to add folders and songs at the same time
PostPosted: Mon May 09, 2022 10:22 am
Right click on the Media Player icon, select 'Media Player Settings' to open the configuration dialog.
Drag the folders to the panel at the LEFT to create multiple playlists based on each folder's name OR drag the folders to the panel at the RIGHT to crate a SINGLE playlist with all the music files in all your folders.
Users browsing this forum: Amazon [Bot] and 49 guests
