 Post subject: Re: Re: Nextstart Multi Monitors
PostPosted: Thu Mar 17, 2022 10:34 am
I would also like to see better support for multimonitor configuration. I think the start menu needs to work on all monitors, independently open on click.
The Buttons that show which program/window is open should only be active on the current monitor to which that p/w is open on.
I would like to see the option to centre the task buttons. At present I can span the taskbar but when you centre the buttons it looks untidy on two monitor config.
PostPosted: Thu Mar 17, 2022 5:35 pm
Reading the topic under which you posted this, you should have realised that your points had already been addressed there - more or less. Furthermore, you must never post to an old thread where the last post is more than 6 months old - please study the Board Rules and Guidelines.
How will it all end?!
IN FIRE!
Users browsing this forum: No registered users and 21 guests
