 Post subject: Nexus Icon on Dock
PostPosted: Tue Feb 15, 2022 12:49 pm
Sorry if this is a no-brainer. I haven't found the question by doing a forum search.
My Nexus Dock includes the Nexus icon at the left end of the bar, as per the attached image. Is there a way of hiding it, while keeping all the other icons?
Thanks.
 Post subject: Re: Nexus Icon on Dock
PostPosted: Tue Feb 15, 2022 4:09 pm
Right-click on the Nexus icon, select 'Dock Properties' - or it may be just 'Properties' - and a tabbed panel will pop up with all sorts of options for configuring the dock. Among these, somewhere, is an option to 'Disable Dock Control Icon'. Sorry I can't be more precise as I'm currently on Linux rather than Windows, but all it'll take is a little looking around, exploring. :)
How will it all end?!
IN FIRE!
PostPosted: Tue Feb 15, 2022 4:19 pm
Got it.I just hadn't looked carefully enough.
Many thanks.
