 Post subject: LCD Alarm on NEXUS without song
PostPosted: Thu Dec 30, 2021 2:20 pm
I have installed Nexus version 20.10 on Win10 Pro and configured Alarm in the dock. But it stopped playing sound during LCD display even though each alarm is set to a .wav file. When the LCD is displayed, a disabled speaker appears in the lower left corner. Can anybody help me?
 Post subject: Re: LCD Alarm on NEXUS without song
PostPosted: Fri Dec 31, 2021 8:22 pm
When you Edit the Alarm in the Alarms tab of the Alarm Manager window, is the 'Play' button for that alarm grayed out? What happens when you click on it, can you hear the sound?
Also, when you press the Arrow above the Play button to get more settings, what is the Volume set to? Is the 'Use Wake-up settings' option checked? If so, check the settings in the Wake-up tab of the Alarm Manager.
Finally, in the Audio tab of the Alarm Manager, what is 'Kill audio after' set to?
PostPosted: Wed Jan 05, 2022 4:08 pm
Hi Jorge,
Thanks for your help.
R.: The "Play" button is not grayed out, but when I click on it, the text changes to "Stop" and I don't hear anything, until the text goes back to "Play"
R.: Volume = 100%, Brightness = 100% and Nap = 5 minutes
R.: Yes
R.: Volume Inicial = 50%, Volume final = 100%, Tempo do volume inicial ao final = 1 minuto
R.: I couldn't find this option on the Audio tab of my version.
Do you speak Portuguese? I'm from Brazil and I would make it easy, lol
File comment: Alarm edit
File comment: Properties
File comment: Audio tab
PostPosted: Wed Jan 05, 2022 4:11 pm
More images
File comment: Alarm in action
File comment: LCD tab
File comment: Wake up tab
PostPosted: Wed Jan 05, 2022 6:59 pm
first lol, i believe Jorge is from portugal, so he should speak portugese (if i dint mix something up)
second check the windows volume mxer while alarm is playing 'does winstep media player' show up in it?
PostPosted: Fri Jan 07, 2022 2:40 pm
Bingo!!!
That was exactly what was happening. Winstep Media Player was disabled in Mixer.
You saved my life, hahahaha
:D :D :D
PostPosted: Fri Jan 07, 2022 7:23 pm
Olá! Tudo bem? :D
That explains not hearing anything (but you must have disabled it manually) but not the volume icon being grayed out in the alarm above. Glad Seeker suggested checking the Winstep Media Player, I was more focused on the settings.
Anyway, all is well when it ends well ehehe
Users browsing this forum: No registered users and 18 guests
