 Post subject: (Solved) Email Checker not working with Gmail
PostPosted: Wed Dec 29, 2021 10:42 am
Hi guys!
I have noticed that my email checker is not showing email in inbox?
Even if I run check now nothing....?
In the email checker settings I am getting an error for some reason....
The settings are ok but the response message is:
Code:
NO [ALERT] Application-specific password required: https://support.google.com/accounts/answer/185833 (Failure)
Has anyone any idea what the problem is?
bookie56
 Post subject: Re: Email Checker not working with Gmail
PostPosted: Wed Dec 29, 2021 11:00 am
Hi guys!
I have fixed this....
I have two step security for gmail and needed to generate a password for my email checker....
Everything is working again!
bookie56
 Post subject: Re: (Solved) Email Checker not working with Gmail
PostPosted: Wed Dec 29, 2021 11:29 am
Glad you figured out and managed to fix the issue... and it only took you 18 minutes ehehe
Happy New Year! :D
PostPosted: Wed Dec 29, 2021 12:16 pm
Hi :D
It happens a lot nowadays...I have a problem...put it up on a forum and have solved it before I almost finish writing the post....lol
Happy New Year!!
bookie56
Users browsing this forum: winstep and 69 guests
