 Post subject: Taskbar Transparency - Again
PostPosted: Wed Dec 22, 2021 10:31 am
Hello !
was the taskbar transparency issue (as per https://forums.winstep.net/phpBB2/viewtopic.php?f=2&t=9980 ) ever looked into ?
It doesn`t actually matter that much as I`m still using the original setup from when I first installed Xtreme and only use the taskbar module [with hacked resources].
So It still works fine but was just curious.
:Moderator's note - post edited to link to the previous discussion of this topic from >5 years ago as new discussion was split off due to the age of the last previous post. - nexter:
 Post subject: Re: Taskbar transparency
PostPosted: Wed Dec 22, 2021 12:52 pm
Ahah, no, sorry... looks like I forgot all about it.
Just had a look and it seems all it needs is a 'Background only' checkbox.
PostPosted: Wed Dec 22, 2021 2:12 pm
Thanks, as I said it`s no problem as I`m still using the theme I altered over 5 years ago now :D
How time flies.
(Was just doing some housekeeping after a fresh re-install of windows and was checking all the old progs I need and whether any needed updating - as I only use the taskbar module of Xtreme I haven`t "missed" anything to check more frequently)
 Post subject: Re: Taskbar Transparency - Again
PostPosted: Thu Dec 23, 2021 2:29 am
Tidied things up by splitting new posts off from >5 yrs old topic and edited in a link to the old discussion in the first new post, which really should have been a completely new post, with a link back, in the first place.
How will it all end?!
IN FIRE!
Users browsing this forum: winstep and 76 guests
