 Post subject: I can't find the Register Button
PostPosted: Wed Dec 26, 2007 2:55 pm
I received my WinStep Xtreme Registration and it says:
1) Open the Preferences Manager of either WorkShelf or NextSTART.
2) Click on the registration icon at the end of the icon ribbon. "?"
3) Press the 'Register' button on the panel. "?"
I'll be darned if I can find the "Register" button.
Ken
www.runnerduck.com
PostPosted: Wed Dec 26, 2007 6:18 pm
Probably because you placed the key in the Licenses folder and THEN run Winstep Xtreme, in which case the program automatically self-registers.
Check the About tab in Preferences: if it says 'This program is registered to...' you're done! :wink:
Thanks for registering, by the way! :D
PostPosted: Wed Dec 26, 2007 7:29 pm
Yep, that's exactly what I did and I'm am registered. Thanks for your help.
Ken
www.runnerduck.com
Ken
www.runnerduck.com
Users browsing this forum: No registered users and 37 guests
