 Post subject: Weather Update Frequency
PostPosted: Thu Sep 23, 2021 12:31 am
As regards the weather module, no, provider cannot be (user) changed as far as I'm aware. The quarter past setting means that it will be checked only at a quarter past each hour, etc. Check weather only seems to work when there hasn't been a connection and no check has been made by the module within the last hour.
Hmm the update frequency seems pointless. It only checks once an hour regardless so what difference does it make if I check it on the hour or 15 mins. past the hour? The options should be to check it once every 15 min, 30 min, 45 min, or once an hour.
 Post subject: Re: Weather Update Frequency
PostPosted: Thu Sep 23, 2021 1:00 am
As far as I can tell, the update frequency seems to be dictated by the providers, as it is the same frequency in weather applets (modules) that I use under Linux.
How will it all end?!
IN FIRE!
Users browsing this forum: winstep and 76 guests
