 Post subject: Need help editing or removing the default separator - Solved
PostPosted: Sun Sep 19, 2021 11:59 pm
Hi everyone, new user here. I have the toolbar installed and mostly configured. I have running apps showing. Apparently when you show running programs on the bar it adds a default separator between running apps and your other icons.
I want to either delete the default separator or else just edit it. I use a large black dot as my main separator, but the default separator is an ugly green line (see screenshot). I've tried everything I, as a new user, can think of to configure, or delete the default separator, but I don't get a mouseover at all on it at all. When I right click it I get the default menu like when you right click the bar itself.
I'm willing to edit txt files or the registry, but I can't figure out what to edit. Please help, and thanks in advance for your time.
 Post subject: Re: Need help editing or removing the default separator
PostPosted: Mon Sep 20, 2021 12:15 am
As I only use running tasks in the tasklist of the taskbar and never use separators anywhere (haven't done for years!), I'll have to check up on this one when I get a chance, sorry. If anybody else has the answer, please feel free! :)
How will it all end?!
IN FIRE!
PostPosted: Mon Sep 20, 2021 12:22 am
Thanks for your quick reply. Attached is what happens when I right click on the separator itself.
PostPosted: Mon Sep 20, 2021 12:59 am
Unfortunately, we're no nearer to solving your issue, and it could be a while - alas! - unless someone else can help out as I'm not in Windows very often and don't even have it on the system at the moment (I'm mainly a Linux user nowadays) pending a reinstall.
IN FIRE!
PostPosted: Mon Sep 20, 2021 1:06 am
That's fine, and pretty much what I expected. I'm not really in a rush, I was just hoping that, as long as the package has been out someone had already run into this issue.
If it helps, I'm using windows 10 with all the updates. I keep Avira anti-virus running, but this seems to be a pretty straightforward, unrelated issue.
Thanks again for your time.
PostPosted: Mon Sep 20, 2021 5:41 am
I don't use docks myself, but which theme are you using?
PostPosted: Mon Sep 20, 2021 5:46 am
I believe it's the Emerald Green theme. I would imagine though, that it's the same across all themes. That's just a guess though.
EDIT: Whoops, make that Elegant Green.
PostPosted: Mon Sep 20, 2021 5:48 am
Don't have that theme so can't check straight away, but you may need to edit the separator graphic.
PostPosted: Mon Sep 20, 2021 5:50 am
Sorry, that should have been Elegant Green, which is included in the stock release.
PostPosted: Mon Sep 20, 2021 5:54 am
Hhmm... I only installed Winstep a few weeks ago and that theme is not in the set on my machine. So I can't have a look at it.
Have you checked the separator image in the theme files?
PostPosted: Mon Sep 20, 2021 5:58 am
No, I don't know how to do that. I don't have anything that looks like "theme files". I can attach a screen shot of the directory if it helps.
PostPosted: Mon Sep 20, 2021 6:01 am
Just to confirm, are you using Nexus, Nexus Ultimate or Winstep Xtreme?
PostPosted: Mon Sep 20, 2021 6:08 am
The About page says Nexus Ultimate. I know I'm not using Xtrem. Is there a better way to find out?
PostPosted: Mon Sep 20, 2021 6:10 am
Sorry my bad - its a dock only theme. :oops:
Told you I don't use docks :)
How are you inserting your 'black dot' separator?
PostPosted: Mon Sep 20, 2021 6:13 am
Here's a copy of my directory structure. https://ibb.co/wy2w5m4
Sorry I'm on my phone and can't get the editing right. That's the right address though.
Users browsing this forum: winstep and 76 guests
