 Post subject: Nexus Iltimate bars are sometimes not centered
PostPosted: Mon May 24, 2021 1:22 pm
Hello.
On my computer, I have windows 10 and Nexus Ultimate 17.01. I have created 3 bars (one on top, one on the right and one on the bottom).
Sometimes, when my computer wakes up, the bars are not centered anymore (the top one is not centered horizontally, the right one is not centered vertically,...), as if my screen was smaller.
Nexus Ultimate was working fine until a few weeks ago. What should I do?
Thank you.
Translated with www.DeepL.com/Translator (free version)
 Post subject: Re: Nexus Iltimate bars are sometimes not centered
PostPosted: Tue May 25, 2021 2:29 pm
poc36 wrote:
Hello.
Thank you.
Translated with http: (free version)
I can't think of anything that could cause Nexus docks to start up from sleep and being out of their normal alignment. However, there are a lot of weird things that can and do happen to third party apps when Windows wakes up from sleep mode. Unfortunately, there is nothing that third party apps, including Winstep apps, can do about this - complain to Microsoft, not that it will achieve anything.... :(
By the way, 17.01 is a pretty old version by now and there have been many changes since then - and multiple docks were not even available under 17.01! So either you are running a later version, or you can't have multiple docks. So which is it?
How will it all end?!
IN FIRE!
PostPosted: Tue May 25, 2021 4:09 pm
Thank you for the answer.
Yes, my version of Nexus Ultimate is old (I bought it in December 2016). I think it's the 17.01 version (see picture) and I do have 3 docks :?: :?:
Do you think if I buy the latest version, it will work better with Windows standby?
And if so, will I have to reconfigure my three docks (which would take me a lot of time), or will I be able to recover the configuration of version 17.01?
Translated with http://www.DeepL.com/Translator (free version)
