 Post subject: Running Applications and Previews
PostPosted: Sat May 22, 2021 6:56 pm
Is there a way to show multiple dots(*) below running applications showing each instance running? I would also like to see popup previews of the running instances when I hover over the icon in NexusDock. Is there a way to do this?
Dawson
File comment: Red Arrows show running instance dot (*).
 Post subject: Re: Running Applications and Previews
PostPosted: Sat May 22, 2021 8:58 pm
Dawson
Multiple dots for multiple windows of a running app would be nice but at present at least, it's not possible. I'm not sure if it could be done at all under Win 10. Ubuntu Linux's dock does display multiple dots, and I find it very useful. (Ubuntu's my prime OS.)
I'm not sure about previews of running apps under Nexus. They are certainly available with the NextSTART taskbar, so I would assume they are and I seem to recall this being raised in the forums before, but as I'm not in Windows right now I can't check the Preferences for docks and shelves.
How will it all end?!
IN FIRE!
PostPosted: Sun May 23, 2021 1:06 am
Yes I miss the Linux like style.
Thanks for the reply!
Users browsing this forum: No registered users and 18 guests
