 Post subject: Apply HotSpot To : disappeared ? where can i access it
PostPosted: Tue Apr 13, 2021 7:20 am
Hi,
The first time I used winstep extreme, I tried to create, a hotspot
it shows me the area to select in pixels, and window title to track,
but after that, every time I create/edit any hotspot,
I can not get this window, again,
and now my menus appear from everywhere,
but I want to tie it to a specific application,
or specific window,
so how can I access this option again
the option appears in the old docs
https://www.winstep.net/help/ns3/nextstart.htm
 Post subject: Re: Apply HotSpot To : disappeared ? where can i access it
PostPosted: Tue Apr 13, 2021 4:18 pm
Wow. That is a really old version. I can't remember how to use a version that old. Sorry.
PostPosted: Tue Apr 13, 2021 5:17 pm
I think you misunderstand me,
i am not say i use this old version,
i just refer to and old docs,
because there is no docs for the modern version,
but i use winstep extreme v19
so i ask, how can i tie/bind a hotspot,
to specific window/app
i do it before in the same versio,
but after i used it once, it is disappeared,
and does not even appear in edit
PostPosted: Fri Apr 16, 2021 6:31 am
To my knowledge, there is no way to bind a hotspot to another program.
PostPosted: Fri Apr 16, 2021 2:22 pm
So, i can not bind a menu to a specific program or window ! right ?
if yes, this is a very crazy, i just done it 10 days ago,
there is a window appears to me, ask to select window title,
and also select the boundaries of the window in pixels,
and it works very well.
I will try go across all settings and options, so this may exist
in other place.
and you also notice this is exist in the old version,
Also in the docs
The Hotspots Preferences Tab defined as
The Hotpots tab allows you to configure up to 72 independent menus or actions. Each menu or action can be associated to a specific application or window.
but anyway thankyou.
PostPosted: Fri Apr 16, 2021 2:51 pm
I found the solution
to tie the hotspot to a specific window/title
just any option end with Hotspot
1. Right Clicking On Hotspot
2. Left Clicking On Hotspot
3. Middle Clicking On Hotspot
this will show the window to select the are and window title,
But i still have an issue,
exact match, option, will not persisted, it always unchecked,
but it is actually do its job,
so the window title must matched the given title
and this make it useless,
so I will se if this fixed in the last release,
I will upgrade to it.
Users browsing this forum: Apple [Bot] and 23 guests
