 Post subject: New User Question: Drawers vs Shelves
PostPosted: Sat Apr 03, 2021 7:45 pm
I would like to know the difference between and purposes of drawers and shelves. I’ve studied the documents and can’t find the answer. Can you point me to documents that address this? Thanks so much for your help!
 Post subject: Re: New User Question: Drawers vs Shelves
PostPosted: Sun Apr 04, 2021 4:23 am
If you care to look and keep scrolling through the page, it's all pretty much explained here:
https://www.winstep.net/xtreme.asp :)
There are also a few helpful tutorials here:
https://www.winstep.net/support.asp
Plus, there are a few FAQs, and of course lots of info to be found here in this forum also.
Hope this helps. :)
How will it all end?!
IN FIRE!
