 Post subject: Probleme avec la réduction des fenêtre dans le dock
PostPosted: Fri Jan 08, 2021 11:17 pm
Bonjour,
Depuis mon achat, mes fenêtres ne se réduise plus dans le dock, j'ai acheter nexus car il est le seul a proposé sa et sa ne fonctionne plus pourtant l'option est bien activé dans les préférence( minimise windows...).
 Post subject: Re: Probleme avec la réduction des fenêtre dans le dock
PostPosted: Sat Jan 09, 2021 9:55 pm
coreux59 wrote:
Bonjour,
Bon soir, but as this is clearly an English language based forum, if you're seeking help you might consider having the courtesy of appending a machine translation - there are quite a few translation websites around. I appreciate that not everybody speaks English, and I myself have long forgotten all but a few fragments of what French I learned at school.
One thing to note is that machine translations from English to French have a tendency to be widely inaccurate sometimes - it's happened to me on several occasions, to much hilarity thank goodness as once or twice the translation turned my text into highly insulting things in French. :) Hence, I'd rather leave it up to you to try it. :)
PostPosted: Fri Jan 15, 2021 9:45 pm
coreux59 wrote:
Bonjour,
Bonjour!
Unfortunately I cannot find your order through your email address, so I don't know if you ordered Nexus Ultimate or Winstep Xtreme.
If Nexus Ultimate, is the dock set to show running applications (Dock Properties -> Content tab -> Show running applications in this dock)?
Are you running any other application that might conflict with this feature or did you disable minimize animations in Windows? Open windows can only be minimized to one spot, so if two different 3rd party applications are competing for this only one can win (for instance, if you are running Winstep Xtreme and this feature is also enabled for the NextSTART taskbar).
Users browsing this forum: Amazon [Bot], Apple [Bot] and 90 guests
