 Post subject: Why it's happening every time? (icon display issue)
PostPosted: Mon Nov 02, 2020 9:58 am
Hi there,
Some weeks ago Winstep Xtreme has started to display the "Explorer" icon with a blank one. Also grouped icons have the same issue, whatever app it is:
What can I do to repair?
Thanks!
Baio
 Post subject: Re: Why it's happening every time? (icon display issue)
PostPosted: Mon Nov 02, 2020 10:10 am
Did you ever install Stardock's Icon Packager on your system?
From the Winstep Xtreme FAQ:
Q) Icons display the default (blank page) image.
A) This is a bug with Stardock's IconPackager. Open the Windows Registry Editor, go to HKEY_CLASSES_ROOT\exefile\shellex and see if the subkey 'IconHandler' exists. If it does, delete it then reboot.
PostPosted: Mon Nov 02, 2020 2:23 pm
Strange thing... I've never installed the Icon Packager, but this SOLVED!
Thank you very much for your support!
Baio
PostPosted: Mon Nov 02, 2020 2:59 pm
It's one of those things. :P Glad I could help. :)
Users browsing this forum: No registered users and 25 guests
