 Post subject: Cannot create directory
PostPosted: Thu Oct 29, 2020 9:17 pm
Hi All,
I am trying to install Winstep Nexus 19.2 Dock onto my Windows 10 PC.
Firstly, when I got to https://www.winstep.net/nexus.asp I get this error message. 403 - Forbidden: Access is denied.
I got around that my downloading Winstep Nexus 19.2 Dock from a mirror. But it will not run the setup.exe. In the attached image it tells you the error.
I did not change the folder it wants to install into. I did try and change that folder but got the same error message.
Any thoughts on how to resolve this error?
Regards,
Rob
 Post subject: Re: Cannot create directory
PostPosted: Thu Oct 29, 2020 11:18 pm
That's likely because the anti-ransomware "feature" in whatever security software you're using is *silently* preventing the Winstep application from creating a folder in a perfectly legit location.
PostPosted: Fri Oct 30, 2020 1:14 am
Yep you were right.
Got it installed and running well,thank you.
Is it possible to add a Windows search function to the dock?
Cheers,
Rob
PostPosted: Fri Oct 30, 2020 1:28 am
Depends on what you mean by that. Check up on the available Internal Commands.
