 Post subject: Digital Clock Module Icon Directory
PostPosted: Sun Sep 27, 2020 6:57 pm
Where can I find the directory that the default clock/calendar module "icons" are in? I see there is an option in clock properties to change the icon, and it gives a preview of the original background for it. I'd like to know where that icon is located so I can do a simple recolor on the calendar portion.
Moreover, does it even work that way? Or will modifying it compromise its functionality?
(PS. Using Winstep Xtreme non-trial, if that makes a difference)
 Post subject: Re: Digital Clock Module Icon Directory
PostPosted: Mon Sep 28, 2020 12:15 am
I am pretty sure it's compiled directly into the program's module(s).
PostPosted: Mon Sep 28, 2020 8:14 pm
As, indeed, am I. In which case, you'd have to hack into the exe and look at the resources, and when you find the icon copy it out, re-work it, and then overwrite the original in the exe with that. Done that a few times. Usually a piece of cake, though it's advisable to keep to the exact same file size (in terms of bytes).
How will it all end?!
IN FIRE!
PostPosted: Wed Oct 28, 2020 8:13 am
Don't do that. Winstep applications check the integrity of their own exe files, and will stop running if they are changed in any way (you will get a big red warning dialog).
PostPosted: Thu Oct 29, 2020 5:55 pm
Yeah, I know, just forgot to mention it. Not that I'd dream of doing it with Winstep anyway, but if I were to, I'd save a copy of the exe first to drop back in if things went awry. I used to do stuff with what were clearly abandonware apps only. Before Nexus came along I used to do it with the old Icondock - a different exe for each Winstep theme I used. :) (Hell of a job though - over a hundred gfx files to change IIRC!)
Anyway, great to see you back Jorge! :) Hope you're fine.
IN FIRE!
