Board index : Winstep Forums : General Discussion  [ 30 posts ] Go to page 1, 2  Next
 Post subject: When?
PostPosted: Fri Aug 21, 2020 6:11 pm
You all know what I am referring to
 Post subject: Re: When?
PostPosted: Fri Aug 21, 2020 7:36 pm
No, some or even a lot of us do not - do not make such assumptions. And use titles that actually say and mean something. On a fully moderated forum a moderator or admin would already have deleted your post, inc. on every other forum I use.
PostPosted: Fri Aug 21, 2020 8:14 pm
When What? That is a weird post if ever I read one......
PostPosted: Sat Aug 22, 2020 7:13 am
Oh, well I'm sorry, I was under the impression that absolutely everyone here is waiting for the same thing I am - the next version
PostPosted: Sat Aug 22, 2020 1:59 pm
Why would you need a new version?
PostPosted: Sat Aug 22, 2020 2:00 pm
Why would you want a new version?
PostPosted: Sat Aug 22, 2020 2:45 pm
There you go again, assuming. You know what happens when you assume, don't you? Yeah, exactly.
You should never, ever make assumptions when posting in any forums, whether in Winstep ones or anywhere else. They are generally not well received by both other users and staff. About the only assumptions that are reasonable is to assume that, e.g., nobody else knows what the hell you're talking about, or that there are a lot of folks there who are still newbies and need to have things made clear and easy to understand.
Bear that in mind and your posts will be much better received.
PostPosted: Sat Aug 22, 2020 5:23 pm
Remember you can get the beta of the latest version (v20.x) by checking the appropriate setting in the Advanced tab of Preferences and then checking for updates.
Official release... soon, but the beta is pretty much feature complete.
PostPosted: Fri Sep 04, 2020 5:03 am
No, some of us are waiting for that which must not be named for fear of delaying it another 7 years.
PostPosted: Fri Sep 04, 2020 6:36 am
Oh ye of little faith! :D
PostPosted: Fri Sep 04, 2020 10:30 am
I think it's time our faith would be rewarded :)
PostPosted: Fri Sep 04, 2020 11:51 am
Salvation is not a reward, it's a gift! :P
But I kind of agree eheh
PostPosted: Sun Sep 06, 2020 6:42 pm
I just renewed, checked my settings and restarted but I get nothing about any available beta when checking for updates. Windows 10 - 1909. According to Workshelf I'm on version 19.2.
PostPosted: Mon Sep 07, 2020 8:54 am
Heh? That's a new one.
Can you please restart Winstep Xtreme, manually check for updates again (making sure that 'notify of betas...' is checked), go to the About tab of Preferences, click on the version number in the top right corner, and post a screenshot of the Version Information dialog that pops up?
PostPosted: Tue Sep 08, 2020 12:38 pm
OK. Exited, restarted PC, checked firewall settings (just in case). Beta and updates are checked as before and this is what I get:
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 30 posts ] Go to page 1, 2  Next
Users browsing this forum: Amazon [Bot] and 201 guests
