 Post subject: Flicker on full screen windows
PostPosted: Thu Sep 17, 2020 3:18 am
Just purchased Ultimate today & love the software, its been absolutely amazing.
However Im having a major issue where my windows will glitch on the top when full screen. It happens constantly as a change tabs as well. Ive narrowed it down, tested disabling all 3rd party software & without Nexus running I dont get the issue.
I managed to snag a screenshot with my editing software & it looks like a bar with text info of the page Im on.
Appreciate any help, would love to continue enjoying the program. Thanks!
 Post subject: Re: Flicker on full screen windows
PostPosted: Sat Sep 19, 2020 8:00 pm
Went back to chrome & seemed to fix. Still having issue with spotify unfortunately.
PostPosted: Sat Sep 26, 2020 9:41 am
Settings > System >Display > Advanced display settings > Display adapter properties > Monitor > Screen refresh rates. It's a long shot, but it may improve the screen flicker with a higher refresh frequency.
shareit app vidmate
PostPosted: Sat Sep 26, 2020 9:44 am
Appreciate it, I'll definitely give it a shot. Thanks!
PostPosted: Wed Oct 28, 2020 8:22 am
Also, try Preferences -> Tasks -> Advanced -> disable 'Show icons of running applications as window thumbnails'
See if that solves the issue. If it does and it only happens with a particular browser, you can always re-enable that option and add the browser to the Thumbnail Exclusion List.
PostPosted: Wed Feb 10, 2021 9:10 am
Screen flickering in Windows is usually caused by a display driver issue or incompatible app. ... Then, based on that information, you'll need to update, rollback, or uninstall your display driver or update or uninstall the app.
shareit get-vidmateapk.com
PostPosted: Fri Feb 19, 2021 11:19 am
Thanks guys for the valuable advices, I solved my problem!
192.168.l00.1 192.168.o.1
