 Post subject: Nexus across 2 monitors
PostPosted: Sat Aug 29, 2020 5:02 am
Hi all, and thanks for any help in advance
I have dual monitors, and rather a lot of items in the dock. I'd like the dock to extend across both monitors (not separate docks), so that the icons are a little larger. Is there any way to accomplish this?
Edwin
 Post subject: Re: Nexus across 2 monitors
PostPosted: Sat Aug 29, 2020 6:52 am
Nope, sorry.
A dock is supposed to be a repository for a relatively small number of quick launch items, and not to hold everything plus the kitchen sink. :) In the latter case it is best to use menus, shelves, or other type of objects that are better suited to holding a large number of items.
Assuming you are not running the free version, you can instead try organizing/categorizing the items in your dock into either sub-docks or grid stacks.
PostPosted: Sat Aug 29, 2020 7:02 am
Thanks for that
Can i put two docks in place, one on each monitor?
PostPosted: Sat Aug 29, 2020 7:07 am
Yes if you are running one of the paid versions (either Nexus Ultimate or Winstep Xtreme) which support multiple docks, sub-docks, grid stacks, shelves, drawers, etc.
The free version of Nexus only supports a single dock.
Users browsing this forum: Google [Bot] and 94 guests
