 Post subject: Xtreme and NextStart do not load
PostPosted: Sat Aug 15, 2020 2:56 pm
Xtreme and NextStart do not load. WorkShelf is Fine. Tried uninstalling and reinstalling, but get same results. Don't know when this started. Just recently tried to open xtreme.
 Post subject: Re: Xtreme and NextStart do not load
PostPosted: Sat Aug 15, 2020 4:10 pm
Well, Xtreme is basically a combination of NextSTART and WorkShelf. So, if WorkShelf is loading fine, only NextSTART isn't. :)
What happens if you manually launch NextSTART.exe from the
folder? Also, what happens if you press CTRL+F12? Do you see nextstart.exe in the Details tab of the Windows 10 Task Manager?
PostPosted: Sat Aug 15, 2020 5:41 pm
Just want to add to it what Jorge (the developer) said. Right-click on the dock control module usually on the left side of the dock. That's the default red color diamond that says Nexus in yellowish gold.
After the right-click, go to Exit > then left-click on Exit Winstep Xtreme. Check to see if both Run NextSTART at Startup and Run WorkShelf at Startup is checked.
If not, check the one(s) that aren't and restart the PC and see if the problem still exists.
PostPosted: Sat Aug 15, 2020 11:42 pm
Nextstart (32bit) Process in task manager, cpu 0%.
Nextstart.exe does not display anything.
I only have two nexus shelves running.
PostPosted: Sat Aug 15, 2020 11:52 pm
Got the shelf to show, it wasn't enabled. But I only have the Windows 10 start menu.
PostPosted: Sat Aug 15, 2020 11:53 pm
got the shelf to show, it wasn't enabled. But I only have the Windows 10 start menu.
PostPosted: Sun Aug 16, 2020 12:45 am
If NextSTART is running, press CTRL+F12. This should open NextSTART Preferences. Then go to the Taskbar tab in NextSTART Preferences and check which settings are enabled, etc
PostPosted: Sun Aug 16, 2020 11:50 am
On the taskbar tab, nothing is checked.
PostPosted: Sun Aug 16, 2020 3:23 pm
Well, you've answered your own question there - if nothing is checked, nothing will and can show.
PostPosted: Sun Aug 16, 2020 4:00 pm
ok, so what gets checked to get winstep start menu???
PostPosted: Sun Aug 16, 2020 9:40 pm
The setting at the top of the Taskbar tab in NextSTART Preferences that says 'Allow NextSTART to replace the Windows taskbar'.
When that is enabled the NextSTART taskbar should replace the Windows taskbar, and pressing the Start button on the NextSTART taskbar will open the NextSTART Start Menu instead of the Windows Start Menu (optionally, of course).
PostPosted: Sun Aug 16, 2020 9:49 pm
I get the windows start menu.
PostPosted: Sun Aug 16, 2020 11:13 pm
What are the first two options on the context menu that pops up when you RIGHT click the Start Button on the NextSTART Taskbar?
PostPosted: Sun Aug 16, 2020 11:37 pm
Preferences
Associate to Nextstart Menu
I clicked on "Associate to Nextstart Menu" and now it says Associate to Windows Start Menu.
Results still the same. I can't invoke the nexstart start menu
PostPosted: Mon Aug 17, 2020 12:52 am
I would think all this is self explanatory, no?
Now that it says 'Associate to Start Menu' when you RIGHT click on the Start Button, what happens when you LEFT click the Start Button? This time you should get the NextSTART Start Menu, and not the Windows Start Menu.
Users browsing this forum: GPT [Bot] and 93 guests
