 Post subject: SUB DOCK CONFIG FILE
PostPosted: Fri Jul 10, 2020 5:04 pm
Hello!
So I have a question about where I can edit the position of sub-docks once they expand.
I mean this in the sense that currently, they expand too high above the original dock. I want to be able to lower the position to match what I am trying to do.
(It's an OCD thing, I can't help myself)
I presume there is a file that has these settings somewhere and it will just be the case of changing numbers, but I can't find that file.
Any help will be appreciated greatly!
 Post subject: Re: SUB DOCK CONFIG FILE
PostPosted: Fri Jul 10, 2020 6:28 pm
Have you tried different themes? Sub-docks are positioned automatically according to certain settings and criteria.
Anyway, if you could provide a screenshot so I understand what you mean by 'too high above the original dock' it would be nice.
Also, check out the settings in Dock Properties -> Behavior tab -> Sub-Docks button -> Sub-Docks dialog.
This dialog has some settings that by their nature will also determine where and how sub-docks open.
PostPosted: Sat Jul 11, 2020 4:24 pm
Just want to lower the expanded sub dock that's all.
Thanks for your help!
PostPosted: Sat Jul 11, 2020 4:59 pm
The distance also depends on the dock's background. You have your dock's background set to be fully transparent, so make it temporarily visible and select a different background with smaller outer margins.
Users browsing this forum: Google [Bot] and 96 guests
