 Post subject: Importing modules
PostPosted: Tue Apr 21, 2020 11:57 am
Hello,
Is it possible to import modules (CPU usage, Net Meter, etc...) from another theme into my current theme. I only want to import those specific modules, not the entire theme.
Thank you in advance.
 Post subject: Re: Importing modules
PostPosted: Tue Apr 21, 2020 6:18 pm
I assume you are running Winstep Xtreme and you want some of the desktop modules to have a different theme from the main theme, right?
Each object in Winstep Xtreme can have its own, independent, theme. Open Preferences, go to the Themes tab, then change 'Winstep Themes' at the top right to the module you want to apply a different theme for. You can now select another theme just for that module.
