 Post subject: Remove separator between pinned icons and running programs
PostPosted: Wed Apr 15, 2020 7:57 am
Hey Winstep Forum,
As the post title suggests, I'm wondering if there's a way I can remove the separator between the apps I have pinned to my dock and the rest (running programs). I can't right click on the separator to remove it, as there's no option to do so (unlike my other separators, which I can remove fine).
As of now, it seems like my only course of action would be to either pin everything I have open, or unpin everything else to group everything together. Neither of these options are ideal, but maybe there's something I could edit in a configuration file somewhere that would remove this separator.
Thanks in advance for any help you can provide.
 Post subject: Re: Remove separator between pinned icons and running progra
PostPosted: Wed Apr 15, 2020 8:11 am
As with the MacOSX dock, there is no way to remove the separator that separates pinned items at the left from dynamic items at the right, sorry.
PostPosted: Fri Jul 24, 2020 9:23 am
Is there any way to customize the icon ?
PostPosted: Thu Aug 06, 2020 7:52 pm
Since that particular item is a dynamic separator, no, not directly.
You can, however, customize the image used for ALL separators in that dock, by adding a nxsep.png bitmap to the folder that holds the bitmaps of the dock background you are currently using.
Users browsing this forum: Google [Bot] and 96 guests
