 Post subject: Settings font issue (word wrap and weird shadow)
PostPosted: Sat Apr 04, 2020 8:14 am
First image: Word-wrapping ends up being too tall
Second image: Strange dropshadow effect
My Windows 10 (1909) UI scale is set to 100%
 Post subject: Re: Settings font issue (word wrap and weird shadow)
PostPosted: Sat Apr 04, 2020 9:01 am
Thanks for the heads up.
First case has a story behind it: got an email from a customer literally bad mouthing the application because, of all things, if you clicked on the blank space after the text in a checkbox it would still toggle that setting.
This was actually because of localization issues, in that translations usually use a lot more space than the English original, so the controls had to have blank padding space to make room for extra text. Checkbox controls do not automatically auto-size to fit the text, so this resulted in the issue the customer was seeing.
Since the localization mechanism I wrote already goes through every control in a dialog to translate the text from the original English, to shut him up I used the same routine to actually crop the space used by the checkbox control to the space used by the text portion AFTER translation.
Unfortunately if you then change the text of a control dynamically 'after-the-fact' (i.e.; after loading the form), this skips the routine that automatically adjusts the size based on the amount of text. It must be called specifically for that control otherwise what you see in the first screenshot can happen.
I went over most dialogs looking for those special cases but it's obvious I overlooked that one.
As for the second screenshot, that is actually what a ***disabled*** (grayed-out) common controls checkbox looks like on a black background. You can blame MS for that one. :)
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot] and 44 guests
