 Post subject: Desktop Weathericon without any function!
PostPosted: Sun Mar 08, 2020 9:13 am
Weather desktop icon: No weather data query! Again and again the error message: Connection failed! Unfortunately no connection to the weather service could be established! Reason: Valid name, no data record of the requested type. Please try again later.
And yes, I definitely have an internet connection! And in the LOG it says:
Code:
/data/observations/metar/stations/EDDB.TXT
tgftp.nws.noaa.gov
HTTP/1.1 200 OK
Date: Sun, 08 Mar 2020 09:02:31 GMT
Server: Apache
X-Frame-Options: SAMEORIGIN
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Last-Modified: Sun, 08 Mar 2020 08:53:14 GMT
ETag: "4538efa-3e-5a054045c35e0"
Accept-Ranges: bytes
Content-Length: 62
Vary: Accept-Encoding
Connection: close
Content-Type: text/plain; charset=UTF-8
Strict-Transport-Security: max-age=31536000; includeSubdomains; preload
2020/03/08 08:50
EDDB 080850Z 18008KT CAVOK 05/01 Q1017 NOSIG
Error Decoding METAR Data
/wxdata/weather/local/GMXX0008?cc&dayf=5&link=xoap&prod=xoap&unit=m&par=1023928134&key=712ce1c26b0de059
wxdata.weather.com
HTTP/1.0 200 OK
Server: nginx
Content-Length: 43
Connection: close
/data.aspx?src=vista&weadegreetype=c&culture=en-US&wealocations=wc:GMXX0008
weather.service.msn.com
HTTP/1.0 200 OK
Server: Microsoft-IIS/10.0
X-ActivityId: cebcaf01-4ec1-4b39-9e6f-c6dbdf31a8b3
X-AspNet-Version: 4.0.30319
X-Powered-By: ASP.NET
Cache-Control: public, max-age=591
Content-Length: 1491
Connection: close
<weatherdata xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"><weather weatherlocationcode="wc:GMXX0008" weatherlocationname="Schönefeld, Brandenburg" url="http://a.msn.com/54/en-US/ct52.386,13.509?ctsrc=vista" imagerelativeurl="http://blob.weather.microsoft.com/static/weather4/en-us/" degreetype="C" provider="Foreca" attribution="http://www.foreca.com/" attribution2="Foreca" lat="52.386" long="13.509" timezone="1" alert="" entityid="30065" encodedlocationname="Sch%C3%B6nefeld"><current temperature="4" skycode="32" skytext="Sunny" date="2020-03-08" observationtime="09:20:00" observationpoint="Schönefeld" feelslike="0" humidity="81" winddisplay="15 km/h South" day="Sunday" shortday="Sun" windspeed="15 km/h" /><forecast low="-1" high="7" skycodeday="29" skytextday="Partly Cloudy" date="2020-03-07" day="Saturday" shortday="Sat" precip="" /><forecast low="6" high="10" skycodeday="28" skytextday="Mostly Cloudy" date="2020-03-08" day="Sunday" shortday="Sun" precip="30" /><forecast low="2" high="9" skycodeday="9" skytextday="Light Rain" date="2020-03-09" day="Monday" shortday="Mon" precip="100" /><forecast low="7" high="9" skycodeday="26" skytextday="Cloudy" date="2020-03-10" day="Tuesday" shortday="Tue" precip="100" /><forecast low="10" high="14" skycodeday="9" skytextday="Light Rain" date="2020-03-11" day="Wednesday" shortday="Wed" precip="100" /><toolbar timewindow="60" minversion="1.0.1965.0" /></weather></weatherdata>
Error Decoding MSN Data
* Yahoo Connection Failed...
Valid name, no data record of requested type.
Is there a solution?
Best regards
Blacksmith
 Post subject: Re: Desktop Weathericon without any function!
PostPosted: Sun Mar 08, 2020 2:04 pm
Weather.com terminated their weather feed and Yahoo hid theirs behind AUTH authentication. As such only the NOAA (METAR) and the MSN feeds are currently still working.
However, I just tried your location here and it worked. Looking at your log, it seems MSN also responded but there was a problem decoding the data. Perhaps it's temporary (give it a try now), otherwise go to the Advanced tab in Preferences, enable the 'Notify me of beta (test) versions' then click the Check for Updates button and install the v20.3 beta that was released a couple of days ago.
Make sure your license key will still work with it (i.e.; it is still good for updates) before doing so, though.
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot] and 46 guests
