 Post subject: Google Chrome icon always appears Open
PostPosted: Tue Jan 28, 2020 10:28 pm
I've noticed that no matter what (ie. even when the program is closed) the Google Chrome and Windows Explorer icons in my dock always have the little light/dot under them as if they are open. Is this a glitch or am I missing something?
Thanks for your help!
File comment: Note the light/dots underneath Chrome and Windows explorer (Finder icon) even though neither application is open
 Post subject: Re: Google Chrome icon always appears Open
PostPosted: Tue Jan 28, 2020 11:29 pm
Are you an alter ego of Ryuk trying to drive a point across? lol
Explorer.exe is always running on the background on a Windows system since it's the shell. Never-the-less I already added code for next release so that any icon in the dock pointing to explorer.exe will only show a running indicator if an explorer window is currently open.
As for the running indicator under Chrome, that can only mean that Chrome.exe is currently running, either in the background or as a Chrome App.
Open the Windows Task Manager in the Details tab and see for yourself. :)
PostPosted: Wed Jan 29, 2020 12:10 am
hahah no, but im guessing this ryuk fellow has had the same concern
i sort of suspected as much about windows explorer, but im a bit surprised about chrome
guess google really is spying on me 24/7
those bastards
anyway ill quit chrome and close it in task manager and see if the little dot is still there
PostPosted: Wed Jan 29, 2020 12:13 am
Yeah - looks like Chrome is running all kinds of background processes even after I close the app
Stupid google chrome
anyway, thanks again for your help!
PostPosted: Wed Jan 29, 2020 12:17 am
Ah-ah! Now I can add 'anti-spyware' to the list of features of Winstep applications lol :P
PostPosted: Wed Jan 29, 2020 12:28 am
thanks again
i love this program so much - as you may have guessed from the screenshot it allows me to live in denial and make belief i am still running MacOS as I get re-accustomed to windows after not using the OS for more than 10 years
PostPosted: Wed Jan 29, 2020 5:52 am
You should be able to completely close down Chrome automatically when you close the last active window.
Put this in an empty tab of Chrome.
Code:
chrome://settings/?search=background
It brings up Chrome's Settings and searches for the word 'background'. The last background option (there were three results when I searched) under the System section at the bottom is the one you want.
I have mine enabled because my family and I use Google Hangouts, Google's original answer to Skype.
PostPosted: Wed Jan 29, 2020 7:09 pm
thanks desert dwarf! that did it!
PostPosted: Wed Jan 29, 2020 7:47 pm
Good thing he knew the answer to that one, personally I use Firefox. :)
Users browsing this forum: Apple [Bot], Bing [Bot], GPT [Bot] and 55 guests
