 Post subject: Modules Cannot Detect Location
PostPosted: Wed Dec 18, 2019 3:51 am
I'm just starting to try using modules. However, I cannot get it to show the weather or moon phase for where I am. It's set itself to a city in an entirely different state and will not show anything else. How do I fix this?
 Post subject: Re: Modules Cannot Detect Location
PostPosted: Fri Jan 10, 2020 9:58 am
Open Preferences -> Advanced tab -> Troubleshooting Options button -> Check Internet Connection.
What does it say? If it says everything is ok, right click on the Weather module and select Weather Module Settings. Click on the 'Get My Location' button. Did it get the location right? If not, you can manually select your location from the list(s) in that same panel.
Users browsing this forum: winstep and 44 guests
