 Post subject: Always on top
PostPosted: Tue Dec 10, 2019 9:54 am
I'm running NeXus Ultimate docked at the bottom of the screen. Last Sunday, Windows 10 updated itself to v1909. Since then, the only way I am able to access my dock is to go to the desktop because the icons always go under any open windows. It never did this before so I'm at a loss as to how I can force the dock to always be on top?
 Post subject: Re: Always on top
PostPosted: Fri Jan 10, 2020 10:05 am
Did this still happen after a restart? Z-order can be changed via the right click context menu or in Preferences -> Position tab -> Keep the dock always above other windows?
PostPosted: Fri Jan 10, 2020 11:27 am
After the Windows update and at least 2 restarts performed by the update itself, the issue appeared. Oddly, it stopped doing that after 3 days without any intervention on my part. The "Keep the dock always above other windows" option was already checked.
PostPosted: Fri Jan 10, 2020 12:26 pm
Ah, the joys of living on the edge! Still on 1903 here. :)
PostPosted: Fri Jan 10, 2020 6:07 pm
I wish I had never accepted the upgrade. v1909 has caused me plenty of problems, notably with my internet connection and Office apps. I doubt there's any way I can roll it back now though. :(
PostPosted: Fri Jan 10, 2020 8:02 pm
What happens with your Internet connection on 1909? Just curious.
PostPosted: Sat Jan 11, 2020 5:47 pm
It refuses my WiFi connection which worked perfectly with v1903. I can only connect via LAN now.
In case you don't understand French, it says Nordnet-DD03 isn't secure. This WiFi network uses an old protocol. We advise you to connect to a different network.
Running troubleshooter says there is no reply from the DNS server. It has been like this permanently since the upgrade.
I tried contacting my ISP several times and each time they tell me that a technician will call me back but he never does. :(
PostPosted: Sun Jan 12, 2020 11:06 am
Sounds more like your ISP using a router with an outdated protocol (now insecure) than a bug in Windows 10. :) Still a PITA when it happens.
P.S. My high school French is fine, thanks. ;) Enough to have no problems understanding written text (but, ah, 'fluent' speaking is something else entirely, haven't spoken French in ages lol)
PostPosted: Sun Jan 12, 2020 11:22 am
Well my ISP has adequately demonstrated that his service is now surplus to requirements so, as soon as I am informed that fiber is available here, I will change ISP.
For the moment, at least I can connect via LAN although my other Win 7 based laptop has no issues connecting to the Nordnet network via WiFi.
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot], Majestic-12 [Bot] and 81 guests
