 Post subject: Windows 10 E-mail app
PostPosted: Wed Dec 04, 2019 3:32 pm
Hi all,
is there a way for to working native Win 10 app with "Nexus dock"?
Thank
 Post subject: Re: Windows 10 E-mail app
PostPosted: Wed Dec 04, 2019 9:05 pm
You mean with the Nexus Email Checker module? Create a shortcut in your desktop or in a folder to the Windows 10 Email app (by dragging it off from the Start Menu, for instance) then set the Email Checker module to run the shortcut (.lnk file) instead.
PostPosted: Wed Dec 04, 2019 10:40 pm
Hi,
I've just try that, but notification doesn't work. It launch app only.
Is there another way for get also notifictions?
TY
Users browsing this forum: Apple [Bot], Google [Bot], Majestic-12 [Bot] and 79 guests
