 Post subject: Blue screen problem
PostPosted: Wed Oct 30, 2019 9:14 am
Hi, ive didnt buy the app, but in free version i get this issue(stopcode: DRIVER_IRQL_NOT_LESS_OR-EQUAL, unsuccessful issue : BthA2dp.sys ) and i should uninstall it through go to secure mode and restart the pc! Its happen when i close my laptop which goes to sleep mode and after opening the laptop, the blue screen problem shows and beginning to restart the laptop! very annoying!
Can u solve it!
Thanksfully.
 Post subject: Re: Blue screen problem
PostPosted: Wed Oct 30, 2019 9:26 am
That has nothing to do with the Winstep application, sorry, it is either a hardware or a driver issue. I suggest you do a Google Search for btha2dp.sys bsod
Users browsing this forum: Amazon [Bot], Apple [Bot], DuckDuckGo [Bot], Picco14 and 41 guests
