 Post subject: how to change dock shortcut?
PostPosted: Tue Sep 10, 2019 3:48 pm
i'm using eclipse for coding. when i try to run code(ctrl + f11), dock setting appear on the screen. it is very annoying, how to change it? :cry:
 Post subject: Re: how to change dock shortcut?
PostPosted: Tue Sep 10, 2019 10:48 pm
Go to Preferences - General tab
you can change the shortcut key there.
Users browsing this forum: GPT [Bot] and 40 guests
