 Post subject: Unable to show running application instance from dock
PostPosted: Wed Sep 04, 2019 5:23 pm
I added Creo Parametric as an item to the dock. It shows up correctly and when clicking on it from the dock it shows that there is a running instance. However I am unable to click on it without it creating a new instance of it. It shows on the windows 10 taskbar and I can do everything as expected. How do I make it where the program only opens once and I can minimize and maximize it? I just downloaded the dock so it is the latest version.
 Post subject: Re: Unable to show running application instance from dock
PostPosted: Mon Sep 09, 2019 6:50 am
In the behavior tab of that dock's Properties dialog / Nexus Preferences, is 'Do not launch multiple sessions of the same application' enabled?
If so, does this only happen with Creo Parametric ? Some applications can also use a proxy 'launcher', so please make sure the executable name for launching Creo Parametric from the dock is the same that appears in the Details tab of the Windows Task Manager when Creo Parametric is running.
Users browsing this forum: Apple [Bot] and 21 guests
