 Post subject: Windows 10 Action Centre & Task View
PostPosted: Fri Aug 09, 2019 3:04 pm
I was wondering if there was a way of accessing both the Windows 10 ‘Action Centre’ and the ‘Task View’ through Nexus Ultimate when the Windows Task bar is hidden? I want the Windows Task Bar hidden but I use the ‘Action Centre’ often, especially for the Quick Actions.
 Post subject: Re: Windows 10 Action Centre & Task View
PostPosted: Fri Aug 09, 2019 3:10 pm
The Hot key Win+A works to launch the Action Centre although it would be good to create a Nexus shortcut for the dock.
PostPosted: Fri Aug 09, 2019 10:24 pm
I think you should have a look at the list of available Winstep internal commands. :wink:
PostPosted: Sat Aug 10, 2019 10:06 am
Perfect, they do the job. Thanks.
Users browsing this forum: Amazon [Bot], Google [Bot] and 89 guests
