 Post subject: Effects Lag
PostPosted: Fri Jul 05, 2019 2:29 pm
I'm running Nexus Ultimate v19.2 on Windows 10 Enterprise 64-bit Build 1903 on the following hardware...
    HP EliteDesk 800 G4
    Intel Core i5-8500 CPU @ 3.00 GHz
    8 GB @ 2667 MHz
    SAMSUNG MZVLB256HAHQ-000H1 256 GB SSD
    Intel UHD Graphics 630 with 512 MB dedicated
All drivers, software, and Microsoft updates are current.
The behavior I'm observing is that there is a significant amount of lag with any (and all) of the effects (mouseover, launch, attention, and delete). I can see lag/stuttering just going to Dock Properties | Effects and watching the little demo of the effects. I just recently moved from Windows 7 to Windows 10 on the same hardware and didn't see this same behavior on Windows 7.
I've tweaked every setting I could find and nothing changes the behavior. I'm hoping for some suggestions on what else to check/try.
Thanks.
 Post subject: Re: Effects Lag
PostPosted: Fri Jul 05, 2019 2:36 pm
Never heard of an issue like this before, sorry... to me it sounds more like a video driver problem...? As in the DWM (Desktop Window Manager) cannot update fast enough?
Also, are you sure your CPU/system is running as as fast as it should? Check out CPU-Z, system benchmarks, etc...
Users browsing this forum: Amazon [Bot], Apple [Bot], Google [Bot] and 78 guests
