 Post subject: 18.2 phantom task bar apps
PostPosted: Thu Apr 25, 2019 1:34 pm
When the task bar seems to get full, and I close a few apps, the last one in the task bar seems to get stuck fading out.. the app is closed.. but its like the graphics get stuck..
 Post subject: Re: 18.2 phantom task bar apps
PostPosted: Thu Apr 25, 2019 1:57 pm
What happens to the 'stuck' button when you then open a new application? Does it go away?
PostPosted: Thu Apr 25, 2019 4:49 pm
No it stays there until I reboot basically.
It gets some odd overlap on graphics...
PostPosted: Thu Apr 25, 2019 10:12 pm
that phantom box just vanished when I closed "Dragon NaturallySpeaking"..
Problem with all this is that it seems to happen more intermittently than anything.. but will take better notice of the task bar and dragon from now on...
Users browsing this forum: Google [Bot] and 35 guests
