 Post subject: itunes and winstep are crashing (maybe simultaneously)
PostPosted: Tue Apr 16, 2019 8:33 pm
Not sure which is the culprit but itunes seems to be not playing well with workshelf.
If I start itunes (intel PC, Windows 10 Pro 64 bit, 32 GB memory, 1 TB SSD (~15% full), LAN network, bluetooth speaker (bose)) sometime between 2 and 25 minutes, both itunes and workshelf crash... just stop in their tracks. This only seems to be happening with the most recent rendition of itunes.
I have contacted apple and their response was at best meh, uninstall workshelf.
Any ideas what might be happening?
Anyone else having this issue?
 Post subject: Re: itunes and winstep are crashing (maybe simultaneously)
PostPosted: Tue Apr 16, 2019 9:30 pm
Meh, uninstall iTunes. :) :-P
What codec pack do you have installed on your system? K-Lite?
Users browsing this forum: Apple [Bot], Majestic-12 [Bot] and 28 guests
