 Post subject: Multiple Instances
PostPosted: Sat Mar 23, 2019 1:30 pm
I noticed when I boot or re-boot my win 120 PC there are 2 instances of Nexus running. One is version 19.2.1164 the other 19.2.1143. Only the 19.2.1143 shows subdocks and shortcuts. The other version shows empty subdocks and no shortcuts. Should I try uninstall all and re-install latest?
 Post subject: Re: Multiple Instances
PostPosted: Sat Mar 23, 2019 4:54 pm
You're running both the free version of Nexus and Nexus Ultimate.
Just exit Nexus (19.2.1164) then go to
and delete nexus.exe.
No need to uninstall anything, indeed, you should not.
Users browsing this forum: Apple [Bot] and 29 guests
