 Post subject: Import Objectdock shorcuts to Winstep Nexus
PostPosted: Fri Mar 22, 2019 12:31 pm
Hello ... is there a way to move my shortcuts from objectodock plus to nexus ?
Thank you
 Post subject: Re: Import Objectdock shorcuts to Winstep Nexus
PostPosted: Fri Mar 22, 2019 4:07 pm
No, sorry, and you can't do it via simple drag & drop either because OD does not support full drag & drop (i.e.; dragging an item off the dock just deletes that item).
PostPosted: Sat Mar 23, 2019 1:00 pm
Thank you for the answer
Users browsing this forum: Apple [Bot], nexter and 28 guests
