 Post subject: Is possible to change NextSTART button?
PostPosted: Fri Feb 01, 2019 11:52 pm
Hi!
I installed currently in 30 day trial NextSTART.
All is perfect, only one Q remains:
Is possible to change default icon of start button?
Thank you for all suggestions and help.
Miro
 Post subject: Re: Is possible to change NextSTART button?
PostPosted: Sat Feb 02, 2019 1:42 pm
mirkosoft wrote:
Hi!
Miro
It's Winstep Xtreme that you have installed - only way to get NextSTART. :)
No, sorry, you can't change the Start button or its icon - these are set by the theme in use. If you know what you're doing you could change the relevant image files in the theme but you would also most likely have to adjust the respective settings in the NextSTART configuration file - all much to advanced for most people and especially so for a 'newbie'.
Best solution is trying another theme that might suit your tastes better. :)
HTH
PostPosted: Mon Feb 04, 2019 7:04 pm
Ok, newbie in Winstep, but I never said newbie in IT/computing.
I changed successfully Start button and created 4 own themes (only Start button is changed) based on DarkTech.
Only one thing is for me yet unclear - Start button overlay - it forces button to blue and I won't it. It needs to look at deeply.
If you want I can post screenshot.
BTW: I'm using 3 start menus in Windows 10:
native (Windows 10)
Start10 (Stardock)
NextSTART (Winstep - still trial, but looks so good that I'll buy it)
Each menu has own items and I can select primary and reduce categories of each.
Miro
Users browsing this forum: GPT [Bot] and 43 guests
