 Post subject: Winstep Dock snapping to primary monitor after login
PostPosted: Sat Jan 19, 2019 11:09 am
Hey guys,
using Winstep Extreme 18.12. on Windows 10 here.
After booting into windows or switching the windows user, the second dock (which is supposed to be on my secondary monitor) always snaps to my primary monitor; so i've to restart Winstep Extreme every time. Both monitors are connected via Display Port.
Is there any way to prevent this?
Thank you and best regards!
Marc
 Post subject: Re: Winstep Dock snapping to primary monitor after login
PostPosted: Sat Jan 19, 2019 11:15 am
Can you please check if both monitors use the same DPI settings (i.e.; both at 100% DPI or both at 125% DPI) ?
PostPosted: Sat Jan 19, 2019 11:44 am
Thank you for the quick answer!
Are you talking about this windows 10 setting? Theyre both the same for both monitors.
PostPosted: Sat Jan 19, 2019 12:01 pm
Yes.
Ok, so that's not it.
Check
C:\Users\Public\Documents\WinStep\Profiles\
How many files do you have there? Can you attach them to a post here, please?
PostPosted: Mon Jan 21, 2019 9:11 am
Hey, I got three *.ini files in the folder you were talking about.
.ini
98A4B81A3E5FCA636B0BD7A2AA46C748.ini
F5A610D8E0C2377986E081A472F738FE.ini
File comment: 1
Profiles.zip [1.15 KiB]
Downloaded 1400 times
PostPosted: Mon Jan 21, 2019 10:03 am
See if disabling the monitor profiles in WorkShelf Preferences -> General tab -> Misc.Options -> Disable multi-monitor profiles.
I think it will - it's a new feature introduced in v18.12 and it seems like it might not yet be working as intended.
PostPosted: Mon Jan 21, 2019 8:29 pm
Tried this settings, but the problem still occurs when I switch the windows users:
PostPosted: Mon Jan 21, 2019 9:28 pm
Does that mean it no longer occurs when you reboot?
Also, Winstep settings are stored *per user*. This means you will have to disable that setting for *each* of the users on your system. Likewise to positioning the dock.
PostPosted: Tue Jan 22, 2019 8:56 am
After a reboot everything works fine, I just tried switchting the users before.
Thank you very much for your help, problem solved :)
Users browsing this forum: GPT [Bot] and 31 guests
