 Post subject: text on drawer
PostPosted: Thu Oct 25, 2018 7:14 pm
i have a drawer on the left side of the screen for 3 browsers i don't use very often. i've made the drawer transparent, and i keep trying to get rid of name of the idem on mouseover, but i can't seem to find the setting for turning off the labels. is it there, and if so how do i remove the labels? thanks
 Post subject: Re: text on drawer
PostPosted: Fri Oct 26, 2018 12:44 am
You mean you set the number of text lines to None but now you get the floating label when you mouseover the icons, right (there is another - small - label that can also pop up if the tag name is cropped) ?
If so, a 'No Label' option has already been added to Shelf/Drawer icon labels in the next release, so not even the floating label is displayed.
PostPosted: Fri Oct 26, 2018 2:47 am
perfect thanks
Users browsing this forum: Amazon [Bot], GPT [Bot] and 113 guests
