 Post subject: Show indicator
PostPosted: Wed Oct 10, 2018 1:08 am
Hi, I bought a license from your Nexus Ultimate program and I have version 18.10.1120 installed on my Windows 10 Pro Version 1809 (OS Build 17763.55) only I detected a problem. I have active the "Show indicator on shortcuts to applications that are currently running" option but I have detected that there are two programs that do not show this indicator when they are open.
The programs are Spotify and iTunes both downloaded by the Windows Store.
I leave here a print screen with the example of the problem:
Image Image
I hope I have helped and solved this problem soon. Thank you! :wink:
 Post subject: Re: Show indicator
PostPosted: Wed Oct 10, 2018 6:53 am
Thanks for the heads up.
Yes, unfortunately it seems there is still an issue with some UWP apps in the Windows Store. I will be looking into this.
PostPosted: Wed Oct 10, 2018 8:59 am
Thank you :-)
PostPosted: Thu Oct 11, 2018 7:30 pm
Ok, already fixed here.
Users browsing this forum: GPT [Bot] and 33 guests
