 Post subject: Backup Settings : Winstep xtream
PostPosted: Fri Sep 21, 2018 4:47 pm
Hi
I am about to issue the following command ‘Format c:’
My question is how good is the ‘backup settings?’
Do I have to recreate subdocks after?
Or is all that taken care off?
Ive run the dialog I think all I must do is to copy the file it makes and then reinsert it from usb drive latter.
Edit: having gone through the prosess, everything is taken care of bar your desktop walpaper.
oOSGearOo Aka Steve....
Technobable
 Post subject: Re: Backup Settings : Winstep xtream
PostPosted: Sat Sep 22, 2018 8:17 am
Well, a bit too late to answer in time, but Backup backs up all the settings (docks, shelves, drawers, etc), but *obviously* does not backup the actual files (icons, wallpapers, themes, applications, etc...)
Also, when running Winstep Xtreme you must make sure to backup both WorkShelf and NextSTART settings independently.
Users browsing this forum: Google [Bot] and 34 guests
