 Post subject: Win7 Start Menu Icon
PostPosted: Mon Sep 24, 2018 1:57 am
How can I install the glassy Windows 7 Start Menu icon in NextStart? I'm running Windows 10, but miss the shiny Win7 start menu icon.
thanks!
 Post subject: Re: Win7 Start Menu Icon
PostPosted: Mon Sep 24, 2018 11:17 am
The Start Button in NextSTART is defined by the current theme.
If you change the theme, you also change the Start Button bitmap. You can, if you want, apply a theme to NextSTART that is different from the theme applied to WorkShelf - otherwise you will have to edit the current theme's bitmaps directly.
Users browsing this forum: Amazon [Bot], GPT [Bot], Picco14 and 46 guests
