 Post subject: Advanced Skinning...
PostPosted: Fri Aug 24, 2018 11:20 am
Can someone tell me how to get to "Advanced Skinning" please.
 Post subject: Re: Advanced Skinning...
PostPosted: Fri Aug 24, 2018 2:20 pm
What do you mean?
PostPosted: Sat Aug 25, 2018 7:37 pm
WinStep Weather Module:
Weather Module Advanced Skinning
This panel holds the settings for the free-form skinning of the desktop Weather Module. The 'skin' for the Weather Module uses one bitmap image: wsweather.bmp.
The first section holds check boxes to enable 'advanced skinning' and image transparency (the transparent area of the bitmap may be defined using the 'big pink', RGB color 255,0,255). You can also specify here the folder in which the Weather Module bitmaps are stored.
PostPosted: Sat Aug 25, 2018 8:19 pm
GUI Advanced Skinning options were ripped off the application YEARS ago. :)
Users browsing this forum: GPT [Bot] and 33 guests
