 Post subject: Adobe Illustrator and Winstep Taskbar
PostPosted: Wed Aug 08, 2018 8:12 pm
Anyone know of an issue running the .exe file for Adobe Illustratror. The issue is replicated easy, if I use the shortcut I create using the .exe file on the taskbar, certain aspects of the program are very sluggish. If I open or close down the taskbar the program runs fine. If I open an already existing file created with this application via double clicking on the file in a folder, with nexus running, everything is fine. Any suggestions?
 Post subject: Re: Adobe Illustrator and Winstep Taskbar
PostPosted: Wed Aug 08, 2018 8:16 pm
Are you calling 'taskbar' to the dock or are you actually referring to the Windows taskbar? If the former, can you please post a screenshot of the Item Properties dialog for that shortcut in the dock?
Are you using the free version of Nexus or the trial of Winstep Xtreme?
Users browsing this forum: Amazon [Bot], GPT [Bot] and 101 guests
