 Post subject: Runing aplication outside my network
PostPosted: Thu Aug 02, 2018 3:51 pm
Hi,
I have nexus installed in my computer and one of the folders have some applications shortcut. One of them is related to an application outside my local network but im my Active Directory domain. If I run outside of Nexus it will ask to Run or cancel, but if I use Nexus nothing happen, and it won’t run and didn’t show any error.
Any idea?
Rui Reis
 Post subject: Re: Runing aplication outside my network
PostPosted: Thu Aug 02, 2018 4:09 pm
Hi Rui!
Probably related to 64 bit vs. 32 bit folder re-direction.
Not the ideal solution, but try making a Windows shortcut to the item in a *folder* in your hard drive and running that *shortcut* from the dock instead.
You will have to *manually* add the shortcut to the dock (Right Click -> Insert Dock Item -> Item -> Browse or Type path to shortcut/.lnk file) because Nexus automatically resolves shortcuts when using drag & drop.
Let me know if that worked.
PostPosted: Thu Aug 02, 2018 4:22 pm
Thanks for the support. Add the shortcut to the dock solve the problem.
Regrads,
Rui Reis
PostPosted: Thu Aug 02, 2018 5:21 pm
Thanks for letting me know! :)
Users browsing this forum: Amazon [Bot], Google [Bot], GPT [Bot], Majestic-12 [Bot] and 88 guests
